Camon c150
fair1535
....that sort of seizure can cause damage to pot or rings " absolutely bang on.
New plug and fresh fuel sorted the poor running. After 10mins work at home, the only thing I did do right, I suddenly disappeared in a white oily fog !!!!! guess the pot/rings were damaged as suggested, bummer.
Anyone know of independent close to Rotherham who could sort before I cart it off to an established garden maintenance dealer.
Cheers
Steve
if its a honda engine then will need a new barrel and piston set as ali not cast iron. you may be lucky if you take head off that one of the rings broke hence all the smoke may get away with new piston and get barrel polished by a engine rebuilder
