how much overhang?
fergusonforestry
If you measure the distance from the back of the trailer to the centerline of the axle you are allowed 60% of this dimension as overhang. I think its more important to observe the correct marker boards etc so you are on the right side of plod when and if some knob launches a car into the back of you.
Bob
http://arbtalk.co.uk/forum/attachment.php?attachmentid=137457&stc=1&d=1381695035
MAXIMUM OVERHANG
1
Item
2 Class of
vehicle
3 Maximum
overhang
1 Motor tractor 1.83m
2 Heavy motor
car and motor
car
60% of the distance
between the centre
of the foremost axle
and the foremost
point from which
the overhang is to
be measured. (see
note below).Or A
heavy motor car
may comply with
Community
Directive 97/27.
a. A refuse vehicle
b. A motor vehicle which is an
ambulance
c. a vehicle designed to dispose of a
load to the rear, if the overhang does
not exceed 1.15m
d. a vehicle first used before 2 January
1933
e. a vehicle first used before 1 January
1966 if –
the distance between the centre of the
rearmost and foremost axles does not
exceed 2.29m, and
the distance specified in column 3 is not
exceeded by more than 76mm
MAXIMUM OVERHANG
1
Item
2 Class of
vehicle
3 Maximum
overhang
2 Heavy motor
car and motor
car
60% of the distance
between the centre
and the foremost
point from which
the overhang is to
be measured. (see
note below).Or A
heavy motor car
may comply with
Community
Directive 97/27.
a. A refuse vehicle
ambulance
not exceed 1.15m
1933
1966 if –
exceed 2.29m, and
im sure somebody covered this already does it not mean overhang of actual vehicle body not load
more concerned with what it will actually handle than the legal issues, if it sticks out a lot i'll mark the end and get an escort :thumbup1:
Edited by fergusonforestry
had an experiment today moving some wheatley elm, think that is as long as id want to go, somewhere between 6/7 metre (no tape :001_rolleyes: ) I did have two barrels for ballast but the second one obscured vision too much so stuck with one rocked a bit but wasn't to bad on the whole, but unless its a very good bit of timber I think i'll stick to shorter lengths cos the other factor is s**t! how do I get this through the city!? :lol: I took the bypass instead of leaving a trail of broken railings and bent bollards :lol:
handy thing about the trailer is the lights unplug at the rear so can plug a trailer board in at the back
