Stihl clutches on long reach machines
Perkins
I'm having a nightmare with these clutches, on both the polesaw and the long reach hedgecutter. They cease up constantly, making it nearly impossible to start the machine, because the power generated on tickover isn't enough to run the chain/hedgecutter. The only way to start it is to go for full throttle, and keep the revs up all the time. As soon as you throttle off, the machine stalls.
The design of the clutch is poor IMO. The bolts that hold the clutch 'shoes' onto the machine cause so much friction that the shoes don't return to their central position when the revs drop. The spring isn't strong enough to overcome the friction.
I've tried re-building the clutch with the bolts slightly less tight, but they just come undone and then jam the clutch anyway.
Anybody else had this problem?
Yes both are 4 mix engines.
There's just one spring pulling the two shoes together, and it's not an old machine. I'll try a new spring tomorrow, but am not hopeful.
When I dismantle the clutch, as the retaining bolts are loosened, the shoes spring back to the middle, which is what they're not doing on tickover.
I've tried grease, WD40, oil, everything. It's just a **** design. The retaining bolts press the shoes onto the mounting so hard, that they can't pivot.
If the shoes had bearings or shims, or were mounted using nylocks onto partially threaded bolts, that would work, or using set screws instead of long fully threaded bolts.
Thanks for confirmation anyway, it made me feel better somehow, that somebody else had the same problem.
Pretty surprised though, it's like nailing a catherine-wheel tight onto a post and expecting it to spin.
