Wanted feed roller Eco arborist
treeclimbit
The splines are a softer steel than the "male" shaft in the motor so thatvthey tajecthe wear. Cut out the old one and weld in a new female. Put it in a lathe and rotate to check for true, if it is slightly out, then hit the end plate opposite side of the lean to pull it upright!
Just as Dan says!
