What are people's opinions on this?
WillTimberlake
Copied from manual....
11. Trailer Weights
Subject to weighing and manufacturing tolerances, t
he basic Atlas Trailer assembly consisting of drop
down sides and tailgate, wire mesh in-filled ladder
ack and hydraulic pump weighs 985 Kg.
Additional weights of Accessories -
Ramps with supporting prop stands - 70 Kg.
High Side Mesh Kit – 76 Kg.
Partitions – 12 Kg per partition
Spare Wheel – 12 Kg.
Battery – Variable due to make and size
Winch – 11 Kg
It should be noted the total laden weight of your t
railer shall not exceed 3500 Kg.
i.e. Basic Trailer + Additional Accessories + Load
= 3500 Kg maximum.
3.5ton max, but the Mazda will only tow 2.8tons legally, Giving you about 1.5ton payload.
there we go...i was close with a 1 ton load guess then......:biggrin:
that on the back of a 5ton 130 landy and your away....
even with a defender 90 it would take at least 2 ton.....all hail the rover.:thumbup:
