I cut 240mm long which is shorter than most, nothing over 125mm diameter, most around 75mm/100mm. I hand filled about 10 bags from the bottom of a bulk pile last year, about 450/500 per cubic meter bag.
A
I think you may of miscounted mate, that's nearly impossible at the size your processing
i actuley counted a load on to the dmax today 340 logs :blushing:the old nissan used to hold a 90x90x90 bag ,the dmax holds just over 1,1/2 of thses bags :001_huh:so looks like a bit of a price increase needed :thumbup1:
450-500 crickey do you stack them in the bag!!!! theres only so much you can fit in a 1x1x1m bag!!!
ah, but is Alcydon refering to the so called " cubic meter vented log bags"?
I also counted nearly 500 9" long, up to 5" diameter logs out of one of these bags last year, and I now believe that shaken/bounced these bags actually hold 1.4cbm.
Have another look at this thread:
http://arbtalk.co.uk/forum/firewood-forum/51295-stop-giving-your-logs-away.html
