Stihl chainsaw help
tractor10_0
hi its a 66.8cc engine with a power output of 3.3kw
you can put a a bigger bar on if you drop the chain size
check with your stihl dealer they have a bar comparision chart
Er, cc's are not the same as power output - that's B&Q language! Horsepower / kW or torque is, thus the above is the only thread with the answer i.e 3.3kW which translates to 4.4hp. That's 4.4hp in chainsaw terms however is not directly comparable with the hp of a car for instance. In old terminology, 12 horsepower was equivilent to 60 brake horse power, but I could go on forever... Sorry!:001_smile:
