Give mike at sawbits co uk a call as he has lots of old saws in his workshop and may be able to supply spares to you, oh and he can post.
Gave Mike a call had a good chin wag with him nice guy sadly they no longer deal in 2nd hand saws good call though confirmed with him that just about every part including the fuel tank will fit the 020t the only difference is if i use the 200ms fuel tank i will just end up with a flip lid cap which suits me fine to be honest.
  • Replies 22
The differences between the MS200T and 020T are: -
1) Fuel and oil caps - the tanks and crankcase have different cap connectors - the 020T threaded and the MS200t the flippy cap mechanism.
2) Carb on the 020 has the H&L screw closer together and no accelerator pump
3) The cylinder on the 020T has a single transfer each side of the cylinder, on the MS200T, it is split in two to avoid pressure stacking of fuel/air vapour.
4)Air box has an 020T logo and recoil cover has a oblong and not round decal.
5) The fuel tank breathers varied from a fibre insert, to a plug in one and then to a dual fuel line type on MS200Ts
I think that is about it, all parts are interchangeable including the cylinder as stroke and piston are the same on both machines.
The split transfer gives the MS200T a bit more zip on pickup!
Yeah got all that still not found an old version of either though :( I may have an 011 that i can get for free just for taking out a small tree and some lawn waste away shouldn't take me too long so ideal it's more gear in the bank.
