We currently have a very very unhealthy mower. Its got a 443cc Single cylinder Briggs and Stratton engine. It had an oil change last year after i accidentally put 2 glugs of chain oil into the sump but only had 5 mins of running before i realised.
Do you think that may have something to do with it even though the system was flushed through and we had a new filter?
I know from the last time it was banging through the carb it was down to a damaged venturi. But this time there was alot of soot/carbon deposits and oil splattered in the carb inlet.
[ame=http://www.youtube.com/watch?v=ieHDellxjkQ&list=HL1376677035]Very sick DR 1 - YouTube[/ame]
http://www.youtube.com/watch?v=8RxV4fe0Rok&feature=youtu.be
Hmm. Could be a valve issue.
Could be a timing issue.
The video isn't really clear about the noise. Can hear a bang and pop then it stops. Could be a build up of fuel in the system. Running a bit rich. But This normally bangs out exhaust.
It was definately banging both ways which has got us thinking its a combination of valve and timing problems. The dealer is trying to find the clearances on the valves and also the timing.
For it to be banging out of the inlet manifold, I would imagine that the the inlet valve is not fully closing, either due to incorrect clearance, damage to seat, or carbon deposits.
Whilst checking the valve clearance, also check the security of the the rocker arm post.
Valve timing is not adjustable, neither is ignition timing.
See how you get on with that first.
Its the 210000 series with the vertical shaft.
So.004 cold and .006 hot on intake and
.006 cold and .006 on exhaust.
Not too hard to find out I guess. :thumbup1:
