how would I fit a winch on the front of my renault master tipper van iv never fitted a winch so I have on idea
and what size winch would u go for
cheers martin
Speak to a local engineering firm and ask them to build a mount. It needs a tray to sit in and has to fix to the chassis. You should be quite ok with 4-5000lb winch which are relatively small. Wiring needs some heavy duty cable. Wire straight to the earth on winch and battery and for live run it through a heavy duty isolator switch. 300A ones can be found on eBay. The cheap plastic ones run around 120A and won't stand a heavy load well. They are very simple to wire up. A wireless remote system is a godsend as you can be doing a back cut with the remote in your hand :)
