Hi first hedge of the year. Its 44mtr long and there might be one on the back fence 8mtr long. Similar to the one I posted last year when I gave my hedge cutter a test run and you gave prices, but I can't find the post.. If you were wondering how I measured it without seeing it first, there is a distance / area measuring map on a website I found through work. I believe it to be accurate, too. I will be taking my measuring wheel just in case, though. Thanks Luke
Yeah kind of. It is the hedge that backs onto where my brother lives. I've cut me brothers side before. It has a marker system does the webmap, and point A, B and so on it will measure the distance or area etc. It wasn't that far out either. It measured 44m and my measuring wheel measured 38m. Not brilliant, but gives a good ballpark figure. It isn't that bad growing out of the sides, the hedge. A few foot at one end. 1 at most at the other.
actually no. I measured up for it without seeing it. What would you all would charge for it is what I want to know. Last time some said in between £40 and £140 or so. As for heat sending you round the bend. I have been the same myself for the last 2 weeks from about 11AM, if not sooner.
I look at the job with my own eyes, charge as much as humanly possible then use my Easy Lift Harness to ensure the work us quick and easy.
Perfect!
Sent with my iPhone from me, to you!
Couldn't agree more I only once quoted a job blind never again!!
I've been using the truck this week as a work platform saves a lot of time especially with the remote tipper.ImageUploadedByArbtalk1374311935.938841.jpg.ef92c50b554a33139c876f5cae342c6c.jpg
I didn't quote the job blind, I'm going through again to sort price in half hour. I marked up the distance based off a satalite mapping system. It is fairly accurate. I also did post the state the hedge was in just after the original post when me brother phoned me and told me, only I didn't know about any 5 minute wait rule on posting.
