Transit tipper brake problems
NoRush
May be worth checking between the servo and master cylinder I had a flake of rust jam the rod on the master stopping it returning causing the same symptoms only found it when I went to change master after new hoses etc. this was on my 2000 reg smiley.
Was just enough to cause fronts to start to bind heat did the rest would be fine once parked up and ccooled down and checked but a few miles driving loaded would soon have them binding.
Hope you get it sorted.
