Anyone tried it, the outer is the same as the green as far as I can tell but the core is poly as opposed to spectra, so maybe its slightly heavier, but that won't really matter on a prussic. Any thoughts, its a £ cheaper per meter so if there's no real difference I'll just get the red stuff...:001_smile:
I use it on my mainline its works well and lasts as well
Sent using My c
Spectra is stronger/ lighter with less stretch but for Prussic as you mentioned, I doubt that you will notice a difference.
