14 hours ago, sixsix245 said:
It kept painfully kicking back, the 56lb weight doesn't take no for an answer.
Bit much to take on a job though, you'll need a strong branch to hang a pulley on and someone to drop the weight from a convenient height. Otherwise problem solved👍
Edited by peatff
Just open up the coil to flywheel gap, the ignition timing will be retarded ( if you can call it that nowadays) and the saw will be easier to start.
Don't go too far as the spark will stop.
