Or, that could be where the aforementioned large limb was attached, looks like an awfully fresh cut.
Spot on. The dead limb was removed after bark loss and dysfunction ( approx 4 months ago)
Thought so, my thoughts on this tree are ......firewood
Before any more 'burning' thoughts come to mind, consider that the infection appears to be in one vascular pathway. I heed the teachings of Prof. Croft--See trees as a series of units. :biggrin:
That pathway may be infected and compartmentalised, long-term. The story is told underground--check the flare and roots!! :sneaky2:
NOT POSSIBLE to make a prescription, Rx, without a Root Collar Examination, RCX. If the infection is not widespread, one strategy would be soil replacement.
Interesting. The tree owner is a practical farmer type, so ground investigation won't be happening. I think the approach will be to just wait and see how bad it gets, its now weighted away from road so no reason to remove asap.
ref soil replacement; i presume you mean after the tree has been removed?!
Interesting. The tree owner is a practical farmer type, so ground investigation won't be happening. ...ref soil replacement; i presume you mean after the tree has been removed?!
Practical farmers have shovels--that's the only tool needed, tho a trowel and hose can help. Just dig the weeds and soil away from the infected part of the stem--takes mere seconds to see extent of dysfunction.
Why does "soil work" connote "expensive tool--arborists no can do--we climb and cut and that's all"??? :001_rolleyes: Far from the truth.
