If you're just starting out and you need business, equipment, tech or training support you're in the right place. If you've done it, made it, got a van load of oily t-shirts and have decided to give something back by sharing your knowledge or wisdom, then you're welcome too.
Question
bertiebasset
Hi all, new to the forum and also to tree's/gardening in general since a recent house move. Please accept my apologies if this is not the place to get general advice but can anybody confirm if this tree is indeed a weeping cherry? and if so is it the non grafted version? I'm trying to determine what yearly maintenance I need to do on the tree so any advice more than welcome. What I'm planning on doing at present is to let the branches come closer to the ground then keep them trimmed at a desired level then from underneath remove all of the dead twigs which as you may be able to see there is quite a lot of. Anything else I should be doing?
Many thanks
Photos hopefully attached..
6 answers to this question
Register a new accountSign in
