Asulox still available
  • 3 months later...
A couple of points here.
All unused asulux must be returned to supplier. So you should be returning it, not stocking up.
Ramsey7: In no way does glyphosate give better results on bracken than asulux. The reason that there was such uproar when asulux, was banned was because there was nothing better. Can't understand why you say glyphosate is better for the environment than asulux
No problem. Posted it in June thinking I was being helpful and greeted by deafening silence. Not used it before and find it really odd to spray something over several acres and then have no visible sign that I've done it. If I'd bought it off ebay would have thought it was a con. You can now tell the stuff that's sprayed vs not sprayed though as it's dying back sooner.
Unfortunately, all your bracken won't be gone, but you might kill the vast majority. Make sure you go over the same area for the next few years. You should find that it gets less and less each year, until it's finally all gone. otherwise, the bracken will gradually come back. least, that's the experience I've had with the stuff over the last 15 years or so.
