Have you just broken the glass or whole door u/s. If just glass try some of the plant glaziers up here in Aberdeenshire we use Scotglass, must be someone near you.
Good luck as original will be expensive.
yes have cab glass coming to replace ouch £200 for door glass. still thats life. in all the time be using them first bit of glass to get broken in 6 plus years. normally light gets it. thanks for info much apreciated
