Echo CS280
GeeSaw
Hi all
I bought a new Echo CS280WES in October 2012 & fitted it with a 1/4" sprocket & cannon carving bar.
I service my saws & sharpen my chains on a regular basis so I'm sure it can't be down to using a blunt chain or a damaged saw.
But after 30 mins of use I'm getting numb hands /white finger & have to put the saw down until I get feeling back.
Is anyone else experiencing this? Do you think it could be down to the AV rubbers? Or because I've fitted the saw with a carving bar?
Any help would be greatly appreciated
Cheers
Gee
I have one of these saws, was told by ECHO TOOLS UK they couldn't get a 1/4" sprocket so would be interested to know where yours came from, I use the 1/4" tip carving bar but with a very normal 3/8 chain, I've only used mine for 15 minutes or so, so can't say about vibration, will keep an eye out for that though.
Pulsar46, This should help you when placing an order
1/4" Drum Clutch - Part number - A556-000101
Piston stopper - part number - 897537-30130
Tool puller - Part number - x640-000011
If you're looking for a carving bar & chain for your 280 contact Rob D on here or go to his website &
he'll give you a good deal Chainsawbars ? chainsaw chains, chainsaw bars and chainsaw accessories
Hope this helps :001_tongue:
Hi Charlieh, I've heard the 270's are a great saw & some say even better than the 280's,
but I've never heard of a sprocket causing white finger!
Think I might order a new set of AV rubbers & see if this clears things up!
  • 4 years later...
Hi do you know anything about the old cs2800 I was given one in pieces and refurbished it ? It works great but parts are hard to get. I don't use it much but it was nice to get it running.
