husky 45 not idling
Breezeblock
any pointers i have adjusted the idle speed up but it wont idle when hot ive had the exhaust off and there is light scoring on the exhaust side of the piston it also feels quite easy to turn over with the starter anything else i should try before i stick a piston in it cheers
the saw was bought second hand and my brother in law is a serial killer with anything mechanical so a checkered history with the saw i could pretty much guaranteed it will have been caused by oil or lack off, spud can you tell by the marks what the cause would have been heat, oil etc
Pretty difficult TBH, you sometimes get a grey, almost Nitrided looking effect with overheating over a longer period of time pointing at either a slight airleak or carb adjustment being a little out.
If the piston/plug has more conventional colour but seizure is bad, it points to straight fuel/bad fuel.
You are better relying on diagnostic checks to ensure crankcase and rubber part integrity and then a tach to get the carb tune correct IMO.
