It's a bit like you having only one leg, you can stand on it no worries, but one day a strong enough gust of wind will blow you over.
With half the compression and tension fibres removed from one side it's only a matter of time in my opinion, the more time that passes the higher the chances as it will more likely end up as a large decay pocket than heal over that
