In theory you can calculate it for anything under a metric tonne per m3.
If you cut a cube or rectangle place it in water and measure how far up the side the water comes (as a percentage of the depth of that side) - ie
1. A 10 inch cube of timber placed in water, sinks down so 8 inches are below the surface.
2. The timber's density is 80% that of fresh water.
3. Water is 1 metric tonne /M3 so the timber is 800 kg per M3
The difficulty comes if its really heavy and it sinks - then you need more brain power than I'll ever have.
Easy peasy mate,just saturate the water with salt in solution,weigh a litre of the liquid & use the liquid to run your test!:biggrin:
