As the title says - got a project on and need part 1122 400 1214 which is a later model flywheel for a Stihl 066.
The aluminium ones only fit the earlier 13.5mm crank and the poly ones will not fit!
If any one has a wrecker........
Just for info - the 064 one will not fit - much thinner!
L&S Engineers list the correct part number priced at £95.24
Flywheel for Stihl 066 - 1122 400 1216 | Only £95.24 | Other Stihl Spares
It is an option but am hoping for a cheaper secondhand one otherwise I will have a go at setting the flywheel I got with it using a degree wheel - it is a right PITA - the original old model coil has been swapped out and isn't available any more so the ignition timing with the newer coil is miles out - Grrrr!
