545 550xp 5020
Cut4fun
I had to buy a 545 to test out to compare. Here they cost about $100 USD less then 550.
545 is the replacement for the 353.
IMO the 545 out of the box on 1st tank will cut with or out cut a 50cc 346 that is already broken in.
If I was blindfolded I wouldnt be able to tell you the difference in cut between 550 545. JMO
Only differences I found so far is the 545 dont have bells on crank or rev-boost.
Last number on cylinder part number is different and last number on transfer covers different. Physically I see no differences or in running.
Oh and I just had to know how the under $200 50cc PP5020AV was. Needs carb adjusted right out of the box. Just so you know.
Clamshell design, but worthy of occasional use saw.
5020 545 pics
This is the 5016. The bar is the black plain 16" 3/8 050 bars in K041 mount you can buy new still.
I converted this K041 mount long ago to be able to run it on my huskys too with K095 mount, so it works on the 5016 too. ;)
