Difference between 051 and 051av
muttley9050
It would. AV stands for anti-vibration. It's the way the handle is mounted, separated from the engine and bar by rubber buffers, at the back of the handle, under the top cover and at the front at the base, in behind the bar cover.
Other than the AV parts, and associated handle mounts etc, it's the same.
Should add that the reason suffixes such as AV, E and Q are no longer used is because these are now standard features, so it's redundant when they cease to be options.
Alec
p.s. haven't forgotten to look for a bar cover, but there's no power in the shed and I've been getting home too late to go out there and search through the boxes by torchlight!
