No it doesn't need anything else, It's a self contained device. For example the RW relies on a hitch to work on a single line.
You have me confused! It must use a hitch, it doesn't have a clutch like an LJ. Would the LJ or SJ work in place of the hitch?
I suppose it could work instead of the hitch but why.
Anyway, the dog bone is attached to the hitch and the dog bone applies pressure to the climbing rope.
To use a LJ you would have to attach it to both ends of the dog bone and the dog bone would not be held in place securely enough.
My comment that the HH is a self contained unit, i meant that the metal parts and the hitch cord are designed together to work without anything else. Anything else introduced to the system would corrupt the design and functionality.
Same could be said for the wrench, that's a self contained unit where the hitch cord and metal parts are designed to work together I mean you don't need a pulley to have the system work it helps.
Sent using Arbtalk Mobile App
I think old mill means that the cord is actually part of the HH Ewan :001_smile:. The wrench can be attached to any primary friction device, the HH can only be attached to a close mounted closed hitch.....
