Well, finally got around to heading out to an old clients house to start on the cherry butts.
took a while faffing around getting things setup, but soon got under way.
was using the 36" mill, grandberg chain and 064.
was a dream to use, took 2hrs to get my boards. the biggest being around 12" wide but both 8ft long. needless to say the big butt, had a touch of wood maggot so ended up cutting the center section out of two boards which was a shame.
so, what is the price for cherry these day? big tree was cut 2" planks, the smaller tree was cut 1.5" so to get a few more boards.
simon
Very good milling - clean finish.
I'd aim for the £15-18 a cubic foot mark for fresh sawn cherry. Air dry it to 18% and you can add a tenner onto that. Kiln dry it and it's another £7-10 and it's much easier to shift.
Big Beech, great job! Nice to see you underway so soon. That Granberg chain gives a lovely finish indeed. I'm using a modified Carlton filed at 10 degrees and it does the job passably well. A little sanding and you've a smooth board. Less complicated sharpening I find.
Shame about the loss of wood to maggots. Bad year for flies this I reckon :thumbdown: seen mozzies and allsorts and it's only February. Now it's just time to sticker, end seal and store! Good luck with the benches/sale.
yeh, midges biting too as of today:thumbdown:
but yes, milling now commencing as customers are getting grumpy ive left butts everywhere throughout my county :lol:
just sharpend the chain with the new grinder from Rob, so will see how she fares next time out. just got a new 7 tooth rim sprok and new aire filter for the 064 .
i also need to check my stickered stack for maggot with a torch, dont want those blighters eatin my hard work!! though i need to get the ends sealed as they are just stacked n stickered and covered with a tarp but allowing a full open ends for drawing the air thru.
simon
