Hi all I'm new on here. :blushing i wanted to ask if anyone would know what size muffler Allan bolt I need for the 357xp it seems to have lost one when cutting firewood the other day it's not the first time something has fallen off. Last month a bar nut fell off I've got a stihl and nothing falls off that??? I've looked on ebay the only ones I can find are over the pond in the USA. If someone knows what size bolt and thread it takes I could get one from the hardware store. I love using the stihl but the husky wins hands down for cutting. Any info would be great thanks chris.
Which one is it
Poss put a pic up
I probably have 1 I could send you or just order a new one as only a couple of squid
  Redthunder said:
Thanks for the speedy response guys. its the main two Allan bolts that hold the muffler to the top end.
M6 X 1.0mm ....not sure about the length of them - take the other out and measure it:001_rolleyes::lol:
  Redthunder said:
Thanks Ill pop out the other one and measure it. Is this common on husqvarna for things to fall off ???
The Stihl guys think so:001_rolleyes: I haven't had anything fall off mine but if an owner says they have trouble with loose bolts, I use a bit of thread lock to retain them!
Typically the exhaust bolts are usually damn tight!
Read more
