ms200t replacement carb
shed_73
You either fit another MS200T carb as a direct replacement, fit an 020T carb - you will lose a little pickup but almost not noticeable - you will also need the 020T rubber grommet side plate where the adjuster screws are accessed - or you can get a grommet with all three holes.
Other than that, the carb has three faults that I know of that can cause some pretty weird idle issues - took me a long while to get fixes in place!
And need to block off the hole that goes into the air filter.
