Just a quick post to say thanks to all the pm's re the MTD top handle saw. As advised I've sacked off that idea and gone with the Wolf Garten 4m extendable pole pruner. Bought it from World of Wolf much cheaper than some other sites, should be here tomorrow. Thanks again.:biggrin:
Just bought one & tried it out first time using any pole saw, & its working well but not used any other brands to compare it with....
Only downsides so far are hard work to cut when its extended to maximum 4 metres as pole bends in middle & teeth smaller & not as agressive as a silky handsaw.
Also you need to section a branch down if alot of weight on it as you can't undercut with em to stop branch spiltting.
Does have a bark blade thing but that doesn't work all the time.
