I get 50 cubic meters on an artic, and my nets are 40L so thats 25 nets per cubic meter. So that's 1250 nets for 50 cube, BUT................... nets are packed neat with no big air gaps, artics are not. so take away a massive 25% volume to be safe and you get 937. I recon you could round it off to 1000 nets.
Fill a net with fresh cut logs = Xkg
Artic load usually 26T (26,000kg)
26,000 divided by X will give number of bags
so if a net weighs 10kg, answer is 2600 nets
less 5% for waste = 2470 nets
if a net weighs 15kg, answer is 1733 nets
May be take 5% off to allow for waste = 1646 nets
if a net weighs 25kg, answer is1040 nets
less 5% for waste = 988 nets
