Transit wheel bearing fail
NoRush
My Y reg Transit tipper driver side front wheel bearing started making a noise and yes is on its way out. Do i have to remove the whole unit off the shock asorber, lower ball joint and track rod ball joint to get the bearing out. ( and no its not a taper bearing). Help and advise would be a great help. Thankyou
Whip the caliper out the way an the hub nut, undo 5 50 torx then lever sort of on back of disk between hub and disk no real need to protect it u will need a big bar tho :-). Once off half of the bearing may stay on the stub ( the bit you lever off) u may need to carefully nip through this bit with disk cutter and knock off with chisel hope this helps buddy
