Chainsaw for milling
tomcorke
Hello
I was just wondering what chainsaw would be a minimum recommendation for milling logs up to about 18"?
Just wondering about cc and length of bar I would need
Also any recommendation's of a good mill for this size?
Thanks in advance
Hello
Thanks in advance
Saw: 90 cc displacement: Stihl MS 660 or Husqvarna 395 (whichever you are used to, and service/parts availability)
Bar: 24"/25"
Mill: Alaskan Mill Mrk III with 24" rails
You'd really want a 70cc saw with a 20" bar...
:001_smile:
I agree that you could possibly get on with a 70cc saw, such as Stihl MS 362.
But you will not be able to cut 18" width using a 20" bar. You loose approx 6" of bar length when clamping the bar to the mill (Alaskan), as you don't want to clamp on the nose wheel.
So would a stihl 362 work with a 12" cut?
12"?!? - no comprendo señor :001_cool:
The MS 362 will pull a 24/25" bar. But it will struggle if you bury it in oak! An MS 441 or 660 would be happier (and faster).
Ripping chain is an advantage, but not strictly required for milling.
A sharp chain is required, though!
Edited by morten
Should have elaborated - if used with the small log mill not the Alaskan - 20" bar will give you 18" cut.
:001_smile:
