The cluster on the stem certainly looks like cuticularis, actually. More 'droopy'. I first thought it was chicken before finding the sporophores on the ground, so think perhaps you're on the mark with cuticularis. As can be seen, these were clustered around a wound site, of which many were still on the stem. Tube layer also looks similar, albeit more blackened in my case. Going back to Dunwich this summer as there's a cracking pub nearby that does awesome food (will go there after for some good cider and food :D), so will check this beech as it's right by the road.
Very nice! Dinky little things. Nice morphology, too - looks spined?
An addition from me, too (from today). I think this is Ganoderma resinaceum on Salix sp. I couldn't get access through the wire fence into the tip site (could only get my hand through the chains and zoom in), though from what I could see it looks like a load of lacquered brackets. Evidently a white rot, as seen by the willow stem's exposed wood.
Nice! Looks a bit like Daedaleopsis confragosa, in terms of its 'blushed' upper surface. Is the polypore one you come across every so often, on willow? I ask, as I'd have put that down as blushing bracket by sheer virtue of the blushed upper surface in part.
This one is a stalked mushroom as opposed to a bracket like confragosa.
It fruits regularly on a few sites on the heath, usually where it's fairly wet.
Can see where your at with the blushing.
Here's what the bay polypore looks like when it first fruits......
ImageUploadedByArbtalk1461698876.032524.jpg.c1bdf88e6566062fe280b1dc7f8b6b72.jpg.
Some impressive shots there. A saprophyte, more routinely, or can it be mildly parasitic? The wood there looks markedly decayed (if we assume the five stages of decay, it must be at least stage 3).
