Not seen that one before but Technorton used to do a similar machine as they had one on a local estate.
Had it been built better it would have not been a bad machine. Never going to be as quick as a normal processor but if it's cheaper to buy it might offset the slower production time enough.
EDIT: Just seen the second video from a different angle - looks pretty much just a saw and elevator with a splitter bolted to it - shouldn't be too bad to put together using off the shelf models.
Edited by Chris Sheppard
We have something nearly the same only benefit i can see with ours we can do shorter lengths on it
Could you stick some photos up?
Im after a saw bench with elevator but if I can get one with a splitter on the side as well jobs a good un
Personally for me there is still too much manual handling in the process. Ram speed looks a touch slow as well though larger hp tractor would change that. I'm finding the metre billet system still quickest if storing outside?
Yeah I do metre billets but I think this style processor with splitter on the side would be next step up from my current saw bench. I may buy a new bench with conveyor and get engineering friend to make me up the splitter bit.
50% of my timber is from hedgerow coppicing and no way would most of that go through standard processor but I could handle it with the processor in question....and this style would still cross cut billets a treat also. And not reply on a ram to push logs onto conveyor
