Tp 200 v tp270
gemtrees
I have u1000 with 130hp engine, I find the 200 very versatile with the turntable but now have tracked chipper for smaller jobs so would use mainly for clearance/forestry work
The only problem we have found with running bigger chippers on our u1600 is that once the mog is loaded with chip you go over your rear axle weight , we found that in the end we were putting the chipper on the front to drive back with !! having said that if we were to try and do that with our Jensen A240 we would be well over on the front axle !!
So in short i would make sure that the chipper is not going to cause you too many problems in terms of axle damage .
