I use an Alpine Butterfly connected to my side with an oval 10mm Maillon.
The tail from the Butterfly hangs to the ground or several meters below me.
Couldn't the mallion come loose rolling against the stem? Surely a 3 way steel krab would be better?
Good points mate, however:
I ensure that the screw is positioned away from the wood and its right in front of my thighs anyway so it's easy to check.
A steel 3way would do the job but an oval Maillon makes a better fit around the stem if the stem is skinny.
I use the same system for my TIP which means chocking something forearm thick. Again, the Maillon creates a good fit.
I no this may sound silly but do you take a spanner up the tree to tighten the mallion or do you just finger tight it?
