Hello,
I'm looking for a large bar for a partner p100 saw I think it's the same fitting as the big huskys, 36" or bigger would be ace, it's for a milling job I've got in the pipeline.
Many thanks
John
partner p100 is the same saw as a jonsered 1020,so you might find more info by looking up the jonsered, hope that helps, cheers, mike
I don't think the fitting is the Oregon D009.
If you go here to the Oregon selector guide OREGON®: Selector Guide
The only bar it lists is 16" and has a D010 mount.
But looking at pics of each mount they do look very similar. Prob wouldn't take much to adapt a bar....
:001_smile:
Cheers Rob, I've just had a look at the Oregon link you supplied and it dosent look like they supply a bar as big as I'd like. I'm beginning to wonder if there is a bar as big as 36" that'll fit a p100, I don't do a lot of milling but occasionally come across a log that's too good for firewood.
It's the same mount as the 2100 Husqvarna which is the same as a 372 if that helps you .The McCulloch version of the p-100 takes Mac 10 series mount bars which depending may or may not interchange ,some will some will not .I can only assume the J-red version uses about the same .
get a 36" d009 mount oregon sprock nose,go to engineering shop and get them to cut the mount out, i did this for my dolmar 9000, worked great
There you go - so if this is the case then the D009 mount will fit...
Have a look here Bar Mount Pattern: 17
as I think you can print these and fit you bar over them to see exactly what you have....
:001_smile:
Great thanks for that, I'll check the d009 pattern with the bar on the saw.
Rob assuming it would fit could you get hold of a d009 bigger than 36"? And have you any idea of cost?
Many thanks
John
