Don't see why not, but it wouldn't be CE then, so why not just make something cheaper up and leave your lanyard as it is?
I've done similar with a cut length of Aeris I had after an embarrassing choice of climbing line routing....
You don't need to mate! The pinto works fine just clip onto the becket!:thumbup1:
I know what your saying , but i tried that a couple of days ago and the VT was just bunching up and not advancing properly . At waist height it works fine , i do use it like that alot . Thats how i thought the HC might align it better .
BTW , are you not in Canada yet ? What has a man gotta do :confused1::biggrin:
Its not CE anyway WW i changed the knot to a VT as i was unhappy at the Distel taking too long to lock . A separate system may be the way to go :001_smile:
PS .. I just noticed your Hi-vis bib last night !! :laugh1::laugh1:
I find its todo with how the crabs orientated mine bunches up on my side strop if the crabs the wrong way round!!
There's a guy on here who climbs on a pinto all the time, I can't remember his name though! :001_huh: hitch climber will probs work better though!
Not made it yet!:confused1: I've been speaking with the guy who posted on here the other week from Alberta Arborist so I'm starting going through the process, how are you getting on?
Nothing doing mate :thumbdown:
If at first you dont succeed though !! :001_smile:
If you changed the pulley to a HC it would still be CE as the HC is CE'd and I doubt because you have changed the knot it would make a difference either mate, after all you would have to change the cord on it at some point so you re- tying either a vt or a distal would not change a thing about the system, me personally would like to see them giving the choice when buying the lanyard to have either HC or Pinto pulley.....
I see no reason why you can't use it as a short secondary work line....:thumbup1:
Yes , at the price it would be good to have the choice to convert back and forth if required . Thanks for the reply :001_smile:
Ah, got you.... What length lanyard do you have, a 10m? They're lovely looking things, I do fancy the 7m version.... maybe on the christmas list...! :biggrin:
And I'm with Adam on the CE bit, I thought it was just the components and the splices which were certified, so long as you use the same cord in a closed hitch it would still be certified, no matter what knot you used? :001_huh:
And yes, I love my hi-vis.. a mate of mine is a lighting director and he did dancing on ice, he pinched a hi vis for me, he knew I'd love the irony as I wobble round up a tree.... I look more like bambi on ice most of the time... :blushing::001_tongue:
