Does anyone have any experience or pictures of connecting the return oil hose to the tractor on an Igland 5002 or similar winch with electrohydraulic control?
I think the idea is to connect the return hose to the tractor's hydraulic oil filler plug but none of the low pressure fittings supplied fit my Valtra's filler plug. The operators manual is not a lot of help except to say that non-pressurized fittings should be used, which is confusing as the return oil hose came fitted with a standard male 3/4" ISO A quick release coupling.
There is a return oil connection for the auxiliary hydraulics on my 6300 but it is also a male 3/4" quick release, but I thought these were pressurized.
Any help would be greatly appreciated. Ta
:001_cool: These sound very similar to the trouble i had a few years back,you will need a Free Flow Return on the back end,non pressurised and very large quick release fittings used to return oil from the system.:thumbup:
I had to fit a "freeflow return " on our case 4230 to run a Bryce Suma post driver. The return had to be a larger bore pipe and fittings.
If you have access to a parts book you may find your auxillary tapping point, mine is under right axle trumpet on rear housing. Some John deeres are just in the rear housing around top link.
I think it will be to dump oil unhindered by hoses valves etc. Try contacting Bryce through their website, or ringing them. They have customers with valtra's and maybe run one themselves I think.
