Seriously great bit of kit. had mine for about 4 years and its a god send when sharpening or touching up chains on a big bar. 168 on a chain takes no time at all, just dab two teeth with a felt tip pen (so you know where you started) an off you go. Great for Granberg chains where you sharpen at 2 angles.:thumbup::thumbup::thumbup:
  • Replies 22
Rob - do you have any videos showing the 3/8" stone in use? It mounts fine, but I can't figure how to get the grinder to lift high enough to allow me to run it over the depth gauge.
Cheers
Alec
Cheers
Alec
Hmmm... not yet - I used one the other day on the 390XP and was fine although that chain only has a third left of it's life...
It may be you have to point the grinder upwards a little if you see what I mean. When I next have it set up I will test on a newer chain.
:001_smile:
