I'm guessing that if the steel is too tough, the cutters will break off easier, at least if they are soft they will flex a little more, be more forgiving? The best "older" machine I have is the Tanaka single sider, the cutters on at are as tough as old boots, but I could never get it just right. I've re-done it yesterday and it's now superb, which has pleased me as it's a great machine for those perfectly straight formal hedges. Of course when a machine cuts well it will be more economical on fuel too.
  • Replies 70
The two times I've managed to bust out a cutter, they have been near the far end, so I've cut off that end and made do with a slightly shorter cutter, or it gets used to rougher work and I keep my best trimmers for best work. Luckily after doing client for a while you get to know where any hidden obstacles are along a hedgerow, either removing or moving them out of the trim line.
I agree with you on Tanaka, Andy, but of course I am a bit biased, as I sell them!
On the economy issue, it also helps to keep them well oiled with a 30 grade oil or similar (engine oil). This increases blade speed, lowers power (and fuel) consumption and saves on the wear between the blades (that pedroski mentioned)
You could always get the attachment that i have that you fit in place of the chain vice on your chain saw grinder then its very easy to use and very sharp every time
Nick
Nick
