Wellingtonia and coast redwood waterlogging issues
APC
Hi,
I have had problems with a high water table, which we initially thought was a burst service pipe. Water had been rising from an old drain amongst some redwood plantings and had consequently waterlogged a large proportion of the root zone. We had attempted to keep the water moving by digging a shallow trench to get it away to a nearby drainage ditch. Once this was in place, it ran for a month after. We had had out contractors to check for leaks as I refused to believe that the water from the drain wasn't a leak. We have loads of old service lines under the park from various layers of history and I guess it is possible that it is an old drain and the water has come from elsewhere but has found the pipe that runs to this. It stopped running about a month after the heavy rain stopped.
The problem is, the 2 adjacent trees, a wellingtonia and a coast redwood, are now yellowing off throughout the foliage, getting worse every day. I am hoping it's not too late to save them. We are on clay, would we benefit from airblasting the root area and applying a mulch? I have read that 2 weeks is pretty much the limit of a tree surviving waterlogging. I'm hoping though that the water being kept moving as much as possible might have stalled this.
Any advice would be pucka please.
Hi,
