stihl trimmer carb issue?
Dean O
Bit confused
problems started with the trimmer cutting out
no fuel showing in the primer bulb even when pumped
when I pump the bulb it seems to pressurise the tank.
good spark at the plug
carb has been stripped and cleaned - was in good nick.
trimmers only a few months old but not having the time to take it to a dealer and assuming that it was only a blocked carb or fuel line thought it would be a quick fix (I was wrong)
any ideas.
many thanks
Dean
I briefly considered this but - they appear to be, unless one of the guys have been fiddling with them before I got to it.
there's a short pipe going to to the lower section of the carb from the fuel tank, the fuel tank is marked with a sign for choke at its origins.
does this sound correct?
