I thought i would like to try a wire core flip line as the ordinary rope is a bit sloppy and i trap my fingers, it hurts.
Have seen one called Dragon Wire Core Flipline at 3m length, 6mm core, on Buxtons site at £35 + p&p + VAT and wondered if this is a good one for the price. I am not a professional.
Also i wondered about making my own out of some cable advertised as follows-----Mooring Rope 12mm Dia. Hemp Fibre Rope with 6mm Steel Braid Core. Dead End Waxed. Live End Spliced quick release marine snap shackles
40M Lengths......
All this length fo about £32 seems good value if it would work.
Any thoughts ???
Edited by Ollybean
dont make your own...:001_huh: its not worth it
buy one,for the sake of £30 to£50,you get tried and tested one which is CE MARKED with a serial no!
if you had a accident using a home made one,you would be in the shat:thumbdown:
ive just bought a 11mm @4m from skyland,with vat and post came to about £50 but worth it
i was using a 13mm@3m with a ISC rope grab but the max rope size for the grab was 13mm,so when the flip line got sappy and the outer sleave gets a but fluffy and bobbly,it gets tight in the grab
40M Lengths......
Any thoughts ???
i made one, you do need to know your stuff, you can do it for £15
