Just away to order the above but I've to choose either the standard or rapide but not sure which one to choose or what the difference is:confused1: so any help appreciated oh and any preference on the size of cord?
Cord depends on rope, i use 8mm on 13mm rope, strictly it's said to use 10mm cord but it works just fine.
Either hitchclimber will work, depends if you want to part with a bit more cash.
Think there both the same price on honeybros site. I use a 13 mm rope so guess either will be fine then
get the rapide, it has bearings. the standard has bushings. Bushings start to squeal after a while especially if you do quick descents..
