im after a replacement cluth for my rayco grinder.
what are the options?
is there a solution that would be more durable?
cheers
iv had 3, rg 20, found the clutshes to be be fairly bullet proof ,are u sure its the clutch & not the belts slipping a tad,
that could be the case.... but the cutter head isnt engaging at all. do you think if the battery was flat that would cause the clutch to not engage properly? as we had to jump start the machine to get it running
check all the wiring ,may justb a lose connection
did it work ok before the battery went down ,had a dicky wire on 1, put a new spade on it was fine ,
hmmm morning at the yard needed i think.
who did you use for parts johny?
west con, got a quote for the brake cable £95+vat ,then fixed it mi sen .not sure whos the dealer now , good belts make a big diffarance ,cheepos wer very quick & soon slip ,owt else just ask :001_smile:
westcon wanted 359 + VAT for a replacement clutch
thanks for your help
not sure but it may be the same as a vermeer ,252,dosko etc, try cross ref numbers wi other makes ,may save a few ££££http://www.google.co.uk/aclk?sa=l&ai=CSUYhxAoTULy8JYad8APJioGgBcT25dkB9Lboziigo4_dAhAEKAZQ9PeewQRgu_6mg9AKoAHggsP-A8gBAakCRaTgCNZhuj6qBCFP0Mm9VxbEH2T-n5FeelY7ATbPTjXIp9jCKqARVMWXjfk&num=4&sig=AOD64_1d5pXAp-uE12mybfB3BOPHNDYgrw&ved=0CIUBENEM&adurl=http://warnerelectric.co.uk
has this come up
http://www.google.co.uk/url?sa=t&rct=j&q=rayco%20rg25hd&source=web&cd=1&sqi=2&ved=0CE0QFjAA&url=http%3A%2F%2Fwww.raycomfg.com%2Fproducts%2F4-mini-work-force%2F3-rg25hd&ei=ogsTUIaCE6et0QXCx4HwBg&usg=AFQjCNH3wT6MkKx1wDrpdwqjiYSHsGGB4w
Edited by Johny Walker
