Just taken the engine to pieces on my MF 550 to find the little man with a sledge hammer. Outcome is No 1 Piston is hitting the head looking deeper found that the big end bearing has gone literally. No top shell and a sliver of metal for the bottom shell. Obviously both crank and con rod is U/S. Does anybody have a 3 cyl engine similar to MF 35 in good condition or know where to get a good recon short engine at a reasonable price. Otherwise does anybody want a MF 550 with a knackered engine.
if you have a college that does ag engineering close to you they might rebuild it for you ;) when i was at the barony we did an engine rebuild as part of the course the guy whose tractor it was was only charged for parts as it was training for us
HI JOHN i no of a mf 35 3 cyl i think it a ad152 and the chap who has worked for M F so no s his stuff thanks jon :thumbup:
HI JOHN my mate has a good mf 35 3cly engine i will ask thanks jon :thumbup:
Much appreciated. I will be down your way in a couple of weeks time for my daughters graduation. Maybe a good time for a slight detour
Get the crank re-ground and oversize bearings for it. Would be a shame to strip it this far and not just get it fixed?
Think it will need a new crank, con rod and piston repair kit (3 pistons and rings) Second hand engine would just be an easier option and maybe more original then the yellow engine which has been put in. (industrial ?????)
