Lumberjake who do you work for in bristol?
Fountain treeworks. I used to work for fountains plc but they pulled out the area when they lost the bristol contract.
You in Bristol?
  • Replies 22
Fair play good comment on using the cord cheers for that. im near the Bristol area (Chippenham). got some work but not tons so if you hear of any pm me on here. you worked there long?
Been in bristol all my life.Started dragging brash when i was twelve,went to college when i was 16 and here i am now. Wont be in bristol for much longer thoughas im off to OZ in september,:thumbup1:
How would you tie the cord off?
Tie a double fishermans at each end,it will tighten itself to the krab when loaded.make sure you tape the tails up to as they may slip out of the knot.Not likely but still not impossible
my bad:blushing:its a single fishermans. if you go into the knot guide on arbtalk it shows you how to tie it in there
