Hi all
Ive got a 625i and the problem i have is that it bangs every time i break or reverse i think its the damper. does anyone know if it can be tightened or is the a repair kit.
Any help would be appreciated
Many thanks
Chris
find the chassis plate and contact the manufacturer for parts and hope its not vermeer.
or find local trailer specialist to sort it as your brakes will not last very long if you leave it.
It's not a matter of tightening or a kit, you just buy a new damper and fit it.
Simple enough job, remove the towing head and the bolt or bracket at the back of the damper
